Upaliti hoces, morat ces samo ponovo programirati daljinsko zakljucavanje. Nesto mi tu "smrdi" na bsi, da prilikom zamjene akumulatora ili reseta bsi-a neko nije ispostovao proceduru do kraja, a ja sam svjedok da ako to ne uradis vrlo brzo pocnu gremlini koje ugl. rijesis ispravnim resetom. Vozio sam dosta auta, posjedovao razlicite brendove i ni na jednom se radio nije palio na pritisak dugmeta na kljucu, vec na davanje kotakta.
U toku dana cu okaciti i proceduru reseta, ne znam da li je za xsaru i c5 ista, pa moram provjeriti, ako me neko ne preduhitri.
UPDATE:
Koliko sam vidio, za sva vozila PSA grupacije postupak reseta BSI je isti, ja sam se vodio ovom procedurom prilikom zamjene akumulatora i reseta bsi-a. Sretno!
You could first of all try a BSI reset to reinitialise the ECUs:
1. Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
2. Ensure all doors are closed and remove key from the ignition.
3. Wait for 4 minutes, disconnect the vehicle battery and wait for 5 minutes.
4. Reconnect the vehicle battery, wait a further 2 minutes minimum (do not open doors, boot, or press any switches)
5. Switch on the ignition only and check system's functionality.
6. Hold lock button on key down for 10 seconds.
7. Remove key open & close door test central locking system.
8. Start the engine and complete the system's check.
9. Failure to follow this procedure could result in incorrect operation of many BSI related items.
