K:Rucica mjenjaca Citroen c5 mk1
Mislim da će ti jedina opcija biti nešto univerzalno, pa to montirati... ne nalazim nikakvu 5 brzina ručicu sa R lijevi :hm:
Fastrs
Htio bi nabaviti orginal, moze mi tko pomoc sa kataloskim brojem? Pa da bas nigdje ne mogu nac tu rucicu to mi je malo cudno. Ovlasteni ce imat samo pitanje koja je cijena.
dekiiii
Evo par komada mada je više varijacija na istu temu:
https://www.aliexpress.com/item/Car-Gear-Shift-Knob-Manual-Shift-Lever-HandBall-For-Peugeot-307-308-3008-407-5008-807/32951842742.html?spm=2114.search0104.3.49.75202dd8iLWbbx&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_10820_10301_10821_10303_537_536,searchweb201603_52,ppcSwitch_0&algo_expid=a12719bf-0513-4cd6-83d1-667008053961-7&algo_pvid=a12719bf-0513-4cd6-83d1-667008053961
https://www.aliexpress.com/item/Newbee-5-Speed-Car-Gear-Shift-Knob-Lever-Stick-Head-For-Peugeot-307-308-3008-407/32905900868.html?spm=2114.search0104.3.185.75202dd8iLWbbx&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_10820_10301_10821_10303_537_536,searchweb201603_52,ppcSwitch_0&algo_expid=a12719bf-0513-4cd6-83d1-667008053961-27&algo_pvid=a12719bf-0513-4cd6-83d1-667008053961
https://www.aliexpress.com/item/Black-Grey-5-6-Speed-Car-Gear-Shift-Stick-Lever-Handle-Knob-Head-For-FIAT-DUCATO/32950668659.html?spm=2114.search0104.3.8.75202dd8iLWbbx&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_10820_10301_10821_10303_537_536,searchweb201603_52,ppcSwitch_0&algo_expid=a12719bf-0513-4cd6-83d1-667008053961-1&algo_pvid=a12719bf-0513-4cd6-83d1-667008053961
i naravno čep:
https://www.aliexpress.com/item/Chrome-Gear-Shift-Knob-Cap-Cover-For-Citroen-C3-A51-C4-Picasso-C8-Berlingo-B9-Peugeot/32974798630.html?spm=2114.search0104.3.2.51c54859qI3A8d&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_10820_10301_10821_10303_537_536,searchweb201603_52,ppcSwitch_0&algo_expid=6aa5a64c-f43c-4429-ad49-f1f48c510ab1-0&algo_pvid=6aa5a64c-f43c-4429-ad49-f1f48c510ab1
ExOduS442xb
Racing
Gdje nabaviti ili kako popraviti - mehanika/kozmetika
Raspada mi se ručica od mjenjača i takvu ne mogu nigdje na internetu pronaći, kupio sam jednu ali ne paše jer rikverc u 6toj brzini a meni u 1oj. Ima li netko ideju gdje bi se mozd mogla nabaviti ručica a da nije sa otpada? Takodjer zamislio sam temu vezano za popravak unutrašnjosti vozila, naime mk1 je već u godinama i određeni problemi vezani isključivo za starost su se počeli javljati. Ni pojas se ne vraća ali prvo važnije stvari.
Probat cu ju vezati plastičnom šelnom za prvu ruku da se ne raspadne skroz. Ima li neki citroen da ima i dalje rikverc u prvoj pa da odgovara sa tog auta? Možda bi tako moglo proći
Da sada ne tražim napamet, daj mi br. šasije ovdje ili u inbox pa ti provjerim cijenu u ovlaštenom.
Problem je u samoj kugli ili koži?
Kataloški broj ručice je 2403.X3, a redovna cijena u ovlaštenom je 380kn :palac-gore:
