Re: Kako da izvadim plastiku oko malog bocnog l. prozora?
Zijev! Dobro jutro. Radni narod pije kavu i sprema se u službu trulo-kapitalističkom gazdi.
Ispod te plastike mi nesto lupka na jednom broju okretaja. I to bas jako lupka. Lupim po plastici pa prestane. Kak da ju skinem?
Sve to imaš u Haynesovom priručniku za Xsaru Pikaso šta je posta
bjelivuk u ovoj temi:
http://www.citroenforum.hr/citroen-xsara-picasso-161/haynesov-priruenik-za-servis-i-popravke-204/
Tek sam na prvoj kavi pa nemam živaca ovo prevoditi, ali mislim da će ti biti jasno. Samo nemoj ništa nasilu i ne bi tribalo bit nekih problema.
1. Wind down the window.
2. Prise off small plastic trim panel - conical shaped - above the main panel in the window corner
3. Prise off speaker trim, remove (?4) screws, pull out speaker and disconnect from loom
4. Pull off window winder knob and trim plate it's splined and just pulls off.
5. Using a very small screwdriver in the small square hole (underneath handle) carefully prise out the door pull handle centre trim. The remove star screws securing the base part of this to the door frame
6. Now the door panel can be removed: Start by using a two flat levers (or thin screwdrivers) to lever it away - starting at the bottom inner corner. You may find, as I did, that some of the panel lugs remain in the doorframe. Carefully remove them and re-position in the panel for later. When all lugs are free lift panel from below to disengage the two lugs above the door opening handle. The plastic weather shield can now be gently and carefully prised away from the bead of adhesive. Note: unless you want to replace the plastic be patient as you pull it away - a bit of very gentle heat near the glue may help.
