Ja sam na VTS pratio ovo
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait at least a minute.
Reconnect the vehicle battery, wait a further minute (do not open doors).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items.
To sam dobio kao upute za c4 II.
Sad mi je palo na pamet da mi je mehaničar skidao akumulator kada i mjenjač, valjda nije nešto zehebao.
