Akumulator ili nešto drugo?!
chewap
Mesožder
Prošle godine u otprilike ovo vrijeme su mi se upalili brisači sami od sebe i svjetla dok sam palio auto. Skinuo sam klemu s akumulatora i vratio natrag i nisam imao nikakvih višeproblema do sada.
Prvo su mi se samo svjetla počela paliti sama od sebe dok ga nisam parkirao ispred zgrade.
Susjed mi zvoni i viče otišao vam je akumulator izađem van a, auto ko božićno drvce sve vanjske lampice upaljene osim žmigavaca i brisači jedva da idu.
Odspojio sam kleme i vratio ih i probao upaliti auto ali ništa nema verglanja samo tišina, a iz uređaja iznad kompjutera se čuje zujanje.
Pozvao prijatelja da preko klema probamo upaliti auto i samo je u jednom trenutku na kratko zaverglao i nakon toga ništa.
Kupio sam novi akumulator spojio ga i ono zujanje iznad kompa je bilo još jače. Auto i dalje ne pali. Nema nikakvog zvuka kad okrenem ključ.
probaj resetirati BSI
ovako:
Put the drivers window down and lift the bonnet (leave the key in the ignition)
Ensure all equipment (stereo etc) is switched off
Ensure all doors are closed and reach through the window to remove the key from the ignition
Wait 3 minutes
Disconnect the battery and then wait 15 seconds
Reconnect the battery and wait 10 seconds (Do not open any doors)
Switch on the ignition (but don't start the engine) and check that all tests pass
Hold the lock button on the key down for 10 seconds
Remove the key, open the drivers door, close it and check the central locking works (I had to hold the lock button down for another 10 seconds at this point)
Start the engine and complete the systems check
ili ovako ko za C3:
Open the drivers window and the bonnet.
Close all the doors, switch off everything, like the radio, phone charger etc.
Remove the ignition key via the open window
WAIT 10 minutes
Disconnect the battery.
(change the battery at this point if this is required, otherwise WAIT 30 seconds)
Reconnect the battery,
WAIT 1 minute
Keeping the doors closed, lean in via the drivers window
Switch on the 'ignition' (Don't start the engine)
Switch on lights (Dipped, normal driving lights)
WAIT 30 Seconds
Start the car
chewap
Mesožder
Hvala, ali na žalost ni jedan ni drugi način ne pale.
Piše kad ga upalim da je aktivan ekonomičan mod
i kad pokušam upaliti motor ugasi se sve.
Ništa od reseta... trebat će ili nova ručica ili centrala od svjetla/brisača, neznam kako je to u C4 riješeno. Na C3 se to češće dešavalo pa je išao opoziv upravo radi toga.
Napravi dijagnozu u ovlaštenom i nek ti daju ponudu...
chewap
Mesožder
Molim? :confused: Sa novim akumularom se brisači više ne pale sami od sebe ni svjetla.
Ne čuje se ni zvuk iznad kompa. Sve je "super" samo se auto neće upaliti :hm:
vborovic
C5 modifikator
Da li ti javlja kakvu grešku za ključ na instrument ploči? Možda je otišao imobilizator, pa ne želi niti verglati, s obzirom da u tom slučaju ne pozna transponder ključa
chewap
Mesožder
Nema nikakve greške osim što piše da je u ekonomičnom modu.
el imaš multimetar ili nekog čisto da provjeriš novi akumulator?
Akumlator je provjeren.
Naručio sam se jučer prek neta u CIB commerce oni su mi najbliži službeni servis pa ću vidjeti što će reći. Moram ga samo odšlepati do njih. Sva sreća pa imam besplatan šlep preko osiguranja. Usput pitam ovdje možda netko zna više dane moram ići do njih :)
Susjed (koji ima privatnu šlep firmu) mi je baš sad rekao da je imao sličnih iskustava da se vjerojatno zaključao komp i da neće ključ pročitati jer sam promijenio akumulator i da u Citroenu trebaju nešto skemijati da bi se upalio.
Ako je to istina onda su stvarno kreativni ti u citroenovom timu za stvaranje problema na autu :)
Aj kad imas vremena isprobavat, probaj sljedece:
-otvori haubu, makni ključ, zaključaj auto, čekaj 5 minuta
-odspoji akumulator, čekaj 20 minuta
-spoji akumulator, čekaj 3 minute
-otvori auto, daj kontakt, čekaj 1 minutu
-probaj upalit
A dobio je, i odradio, već dva reseta... valjda je jasno da ova varijacija na temu nije rekalibracija žmigavaca :D
chewap
Mesožder
hahahahahahahaha na žalost ni ova treća verzija kalibracije žmigavaca nije pomogla :D
Susjedi me već čudno gledaju provlačim se kroz prozor auta, stojim pored otvorene haube i blejim u mobitel :grin:
I dalje je auto u ekonomiji i ne daje nikakav zvuk na paljenje.
biće da se bsi zablesao ili ti nešto vuće struju pa je bacio u eko mod
Ali budu u Cibu to riješili Kod njih sam dosada uvijek bio zadovoljan.
chewap, pogledao sam sliku C4 iz garaže,
ti si iz dugava?
ima u dugavama serviser AMC Marko u Matunovoj, kad kreneš prema ražirnom,
uvijek kada prolazim ima puno citroena parkiranih,
navodno je radio u nekom citroen ovlašt. servisu i sad popravlja citroen,
rekao mi je prek tel. jednom da ima citroen dijagnostičke alate pa bi mogao pomoći
mariola
Cudno da bi se samo zbog zamjene akumulatora ovo desilo....
Moj je bio 3 dana bez akumulatora pa mu apsolutno nis nije bilo.
