Koliko ja znam "1.5" motor je u biti 1.6, samo ima drugi karburator. To je navodno rađeno zbog poreznih razreda u nekim zemljama.
Znači, oznaka je drugačija, nije 16 nego 15, nešto manje konja, al je kubikaža ista.
Istina motor je 1.6, odnosno kubikaža je ista 1580 ccm, samo je smanjena konjaža sa 94ks na 80ks, jer ima jednogrli Weberov karburator 36TLP1/100 a inače jači modeli (odnosno 1.6) imaju dvogrli Solexov.
ja sam imao cx 2000ccm 106 ks, on je gradske trošio do 10l, međugradska 7-9, autoput 180-190kmh(više nije ni mogo) 12l
Takva je potrošnja i na mom bx-u, otvorena cesta oko 8l a u gradu mu ne gine 10-11
koja je oznaka motora, ja imam podatak samo da je xu5 ugrađivan, a to je pežoov.
Ovo je popis svih 1.6 motora u PSA.
1580 ccm gasoline engines
171B (XU5S) BX 16 RS/TRS (Oct 82—Oct 84) XB XB seriesBore × stroke: 83 × 73 mm
Compression ratio: 9.5 : 1
Maximum power: 92 hp at 6,000 rpm
Maximum torque: 134 Nm at 3,500 rpm
171C (XU5S) BX 16 RS/TRS (Oct 84—Sep 88) XB XB/XE seriesBore × stroke: 83 × 73 mm
Maximum power: 94 hp at 6,000 rpm
Maximum torque: 140 Nm at 3,500 rpm
171D (XU5STR) BX 16 for government servicesBore × stroke: 83 × 73 mm
Compression ratio: 8.4 : 1
Maximum power: 88 hp at ? rpm
Maximum torque: ? Nm at ? rpm
171Z (XU5S) BX 16 RS/TRS (Apr 88—) XB XB/XE seriesBore × stroke: 83 × 73 mm
Maximum power: 90 hp at 6,000 rpm
B1A/A (XU51C) BX 15/16 RE (Jan 87—Sep 88) XB EE seriesBore × stroke: 83 × 73 mm
Compression ratio: 9.4 : 1
Maximum power: 80 hp at 5,600 rpm
Maximum torque: 135 Nm at 2,800 rpm
B1E (XU51C/W) BX 15/16 RE/TRS (88—) for Germany and the NetherlandsBore × stroke: 83 × 73 mm
Compression ratio: 8.6 : 1
Maximum torque: 123 Nm at 2,800 rpm
B1F BX 15/16 TGE (Apr 90—)Bore × stroke: 83 × 73 mm
Compression ratio: ? : 1
Maximum power: ? hp at ? rpm
B2C (XU52C) BX 16 (Apr 88—) XB XB/XE seriesBore × stroke: 83 × 73 mm
Compression ratio: 8.95 : 1
180Z (XU5J) BX 16 xI (—Oct 89) for Germany, the Netherlands and SwedenBore × stroke: 83 × 73 mm
Compression ratio: 9.8 : 1
Maximum power: 105 hp at ? rpm
BAZ (XU5CP) BX 16 (—Oct 89) for Austria and SwitzerlandBore × stroke: 83 × 73 mm
Compression ratio: 8.3 : 1
Maximum power: 75 hp at ? rpm
BAY (XU5CP) BX 16 TRS (—Oct 89) for SwitzerlandBore × stroke: 83 × 73 mm
Compression ratio: 8.65 : 1
Maximum power: 75 hp at 5,600 rpm
Maximum torque: 120 Nm at 3,500 rpm
B6D (XU5JA) BX 16 GTi (—Apr 90) for Italy and IsraelBore × stroke: 83 × 73 mm
Compression ratio: 9.6 : 1
Maximum power: 115 hp at 6,250 rpm
Maximum torque: 131 Nm at 4,000 rpm
BDZ (XU5MZ) BX 16 TXi/TZI (—Apr 91) XB FX/HY seriesBore × stroke: 83 × 73 mm
Compression ratio: 9.2 : 1
Maximum power: 89 hp at 6,400 rpm
Maximum torque: 132 Nm at 3,000 rpm
BDY (XU5M 3Z) BX 16 TXi/TZI (Apr 91—) XB FX/HY seriesBore × stroke: 83 × 73 mm
